In a previous post (still open and ongoing) I mentioned problems with my tacho not working.<br /><br />Schematic, you said to check the volatage and gave me wiring options. 4 Wires, gnd, live, ignition and AC.<br /><br />My tacho only has 3. Gnd, live and AC. When I switch on the ignition the (live zero) moves the needle to zero. When I crank the needle wavers around 100 RPM, when it fires - nothing. I checked AC and couldn't see an thing. I don't know what make the tacho is.<br /><br />There are 4 wires going to the tacho. One of them (black) has a terminal ring on it but it is not used and taped back. I presume this is a ground but I can't see where it would go. The tacho only has 3 connections. The tacho also has a setting 1,2,3,4. It is set to 4.<br /><br /><br />Electrics are all working OK as I have just about completed a re-wire. Charging circuit also works.<br /><br />I have no idea where the ac output comes from.<br /><br />Engine is an Evinrude 140 built in 1980.<br /><br />Any advice on this puzzle.<br /><br />Thanks<br /><br />NG
