david
davidgin
I have a yamaha 225 2002 and when I trimmed down the relay would not release, so the trim motor just kept running . The only way to stop it was to turn off the batteries. If i touch the up button on the helm the motor stops as long as I hold the switch. When I turned the battery back on everything works fine, so I guess the relay stuck. Where is the relay located and is it just a plug in type.
