Daft Question
dsc652
Had the upper gearbox of my 290 drive completely refurbished recently.
Can you tell me what size / type of spanner should be used on the two side studs which are recessed into the side of the mid section casting ?
Some seem to see this as a routine removal / replacement to do the bellows etc - is it ?
How do I ensure an airtight seal - dont want water getting in and wrecking the drive.
Many thanks,
Doug
Don S
Re: Daft Question
Takes a 9/16" wrench on the 2 nuts.
Pulling the upper gear box is a LOT easier than pulling the drive. Especially when replacing the bellows. I replaced my bellows yearly when I lived in Alaska, simply because of barnicales on the bellows. I didn't want to be fixing expensive things due to sharp little creatures cutting holes in a part that only costs 65 bucks. Takes a couple of orings between the upper and intermediate, but nothing major.
Install the new bellows per the instructions, and they don't leak. DO NOT over-tighten the clamps, that will cause a leak, and make sure they are positioned correctly (also in the instructions that come with the OEM bellows).
While that may sound like a lot of work, after the first time and you see what is going on, it's a 30 minute job to change the gear lube and replace the bellows. No big deal.
dsc652
Re: Daft Question
Hi Don,
Many thanks for your response.
Have tried an open ender on these, but not sure if I have them tight enough.
Is there a special tool, or a special ring spanner ?
I see in the manual that the VP guy in the picture seems to be using some sort of small box headed spanner ?
Should I have put any sealant on the mating surfaces ?
Regards,
Doug
