1971 Johnson 9.5
Ok, I recently put on a new cylinder head (brand new out of the box) and a head gasket. I also replaced the spark plug wires, ignition, etc...
anyways, I got it all put back together after testing and seeing a good spark on each plug. It wouldnt start for nothing. I pulled my plugs back out to check them to see for fouling or wet and come to find out that they are now being contacted by the piston. The piston is knocking them flat. Its not hitting them too hard because its just causing a slight scratch on the top of the piston. They are new spark plugs...the NGK conversion of the ones my motor calls for.
Could it just be the plug? Surely the cylinder head is fine right?
I was just wondering if this might be a common problem, or what I should do.
thanks
thanks
