alounsbury
Thread starter- Joined
- Jun 29, 2002
- 20
The force engine has a small (approx 1/8") hose that connects from the cylinder drain cover to the intake manifold for each cylinder.<br /><br />If this was plugged or the check value failed - does anyone understand the effect it would have? Could this account for an engine with the following behavior. <br /><br />a) launch boat - no problems with initial 10/15 minutes of operation<br />b) after that - engine will stall if throttle is advanced slowly from idle to full speed at around 2000/3000 RPM. Engine will not stall if punched to WOT.<br /><br />Looking for new ideas since have almost eliminated everything else - carbs, timing, synchronization, etc.
