1_Pull_Wonda
Thread starter- Joined
- Jun 20, 2008
- 11
Have a line on some oversized piston rings (part #203398 superseded to part #378414) for my JW-10. I have decided to go a head and rebuild the power head.
According to my parts list, the over sized piston rings are ?.020 O.S.?. I am assuming this means that they are .020 larger than the standard size. But, that still doesn?t tell me what size the cylinders need to be bored to. I believe, but am not positive, that the original bore size is 1 9/16. Can anyone confirm this ? If so, do I need to have the cylinder bored to 1 9/16 ? plus .020 ? Do the cylinders really need to be bored or is .020 such a small increase that honing the cylinders would work ?
Also, can anyone confirm that I don?t need oversized pistons ? Or that oversized pistons to replace the standard sized pistons were not manufactured ?
Alcan ? F_R ? Anyone else ?
P.S. I have 2 JW-10s. The one with the god compression is not being rebuilt.
