JCF350
- Oct 21, 2007
- 1,149
Re: Cylinder #4 is toast.... please help diagnose (w/ pics)
Not true on the vibration deal. Used to see different sized pistons in brand new engines also the factory rebuilds would come with 2 or 3 different piston sizes. Plus I have rebuilt more than few myself. This is the process called "select fit".
Also note that these were not after market pistons mixed with factory ones.
If you are going to have to bore the sleeve oversized then you should do ALL the cylinders. Not just one or two. If you do, the engines displacement will be out of "square" and the rotating mass will be out of balance significantly. The slight difference in weight with one larger piston will create a substantial vibration at rpm's above 1,200 and possibly even lower. The, "only do the cylinder/'s that are bad", is not a good fix unless you are wanting to off the boat to some sucker.
