Cut trailer to shorten length
Bill2002canada
Hello,<br /><br />Would I cause a problem if I cut about 3 inches off the front of my trailer? I would like to store the boat in the garage this winter and the trailer tongue is about 3 inches too long to clear the door.<br /><br />Also, if it's okay to cut the trailer, what tool would give me the cleanest cut. That 3 inch square tubing looks pretty tuff.<br /><br />Thank you,<br />Bill
Down South
Re: Cut trailer to shorten length
I don't see any problem with cutting 3" off the trailer tongue if you have enough clearance which you should. This means you will need to remove the trailer hitch. Is it bolted on or welded on? If it's bolted on, then no problem. If welded, then the hitch will need to be cut off and re-welded or replaced. A good hacksaw will do the job, just add a little elbow grease. <br /><br />good luck :)
Capt. Bob
Or cut the welded one off and buy a bolt on one......<br /><br />I would put the towing vehicle and trailer into a tight turn on the driveway and check to see if it looked like something might hit the boat before cutting it off though.
one more cast
I used a metal cutting blade on my skill saw (under $10) . you have to cut from both sides on 3 inch square. its a little dirty when cutting but makes a nice cut.
Bob_VT
Borrow a Sawsall. Get a fine tooth metal cutting blade and scribe a square mark. Follow your line and take your time, no speed is needed.<br /><br />I have cut trailer tubes before the same way for variour reasons and never had a problem. <br /><br />Another idea is.... there are companies that sell hinged pieces that can be installed on your trailer. This will allow you to swing the trailer tongue away to fit in a garage. <br /><br />Bob
SpinnerBait_Nut
I thought I seen somewhere, that there was a colapsable trailer hitch that can be put on trailers or maybe it was removable. My mind just went blank. :mad: :confused: :eek: :cool:
JB
I have seen trailers with folding tongues and removable tongues. BOSS makes removable tongue trailers.<br /><br />The two part tongue on my old Magic Tilt can be taken apart by removing one bolt, leaving the tongue about 18" shorter.<br /><br />Good luck. :)
martinwinte
Just a sugestion.... If all you need is 3" and you have a bolt on coupler why not just remove the coupler??? Just back the trailer in the garage and remove the coupler. I belive it would give you your needed 3".
