curious carbs lol
Fun Times
ziggy
does this help?
the last pic clearly says 150 on it imho. and it looks like the 150 came with the possibility of dual carb.
Jgothing
I was told that cover didnt go with the motor, thats what he had found and bolted it on maybe hes wrong since the 150 could have had the dual carbs......and ive if I noticed another casting number above the starter...all I spotted right away was the 473483 ill have to see if u can find the date stamp...so I briefly looked around and found some rebuild kits for the carbs..Scott06 had found those part numbers (thanks man!) but seem to be unavailable, but I searched the numbers and found some elsewhere...so now im wonder if I pull my carbs apart, maybe I can match up the parts and make sure they look the same.... and try that. worst comes to worst they don't fit... try again.. and ill deff have to hook up the shift interrupt switch that Bondo had mentioned looks like I got a direction and im headed that way. thanks for the help!!! maybe this year wifey wont be pissed because the boat actually runs right :D
