Frank Acampora
Thread starter- Joined
- Jan 19, 2007
- 12,004
Simple question, but here's the set-up: It is at speed in the avatar.
I have a 10 foot Cougar Cub tunnel hull powered by a Chrysler 50. It is swinging a bronze 10 1/2 X 14 two blade prop, trailing edge fully cupped from hub to outer edge of the blade, right into where the edge transitions into the leading edge.
The boat goes 40 MPH at 5,000rpm WOT, which is right in the middle of recommended rpm range, so I don't have a performance issue.
However: Above 35 MPH, it starts to porpoise and sometimes chine-walk a bit. The major problem is the porpoising though.
Does cupping increase bow lift? And, if I reduce the amount of cup (the length of trailing edge cupped, not the degree of cup), do you think this will reduce the porpoising?
BTW: As an aside, it burns about 5 to 5 1/2 gals. an hour running full throttle.
