- Jul 23, 2011
- 53,239
Post #2 answered that question
It gains me how I want to operate my motor, regardless of how you operate yours.And I'll go back to my original thought, that your within 200 rpm of max now what makes you think that if you get the extra 200 rpm at WOT will gain you anything at lower rpm with more weight?
yepPost #2 answered that question
If an Uncupped Prop has a Cup added, then yes, the load on the Engine Increases. A 17" prop plus Cup is 17" plus cup(whatever it is). A new cupped Prop, might indeed be 17" cup includedI said..
the question was does a cupped prop decrease rpms , everything else being equal.
Depending on where the Cup is located, is also a factor. Cup on the Trailing Edge, affects Pitch, whilst Cup on the Blade Tip, affects Rake
yepcupping adds performance
so removing the cup will decrease performance
relieving the cup a bit should get you the 200 RPM you are looking for
Yes. More bite = more load on the engine = drop in "work function" for a given fuel input.I said..
I want 6000 when I'm empty....not with 9 people.
Yea Jimmbo we both know that if its cupped, besides the progressive pitch, you can just look at the blade and clearly see the tip of the blades are bent up slightly....I say slightly as I read prop design literature explain that the amount of cup depends on the total prop design and you can have too much so they say.A lot of Props have Progressive Pitch Blades, and the Trailing Edge, will have the greatest Pitch
