Cummins VT903
NathanY
Anyone know anything about them?<br /><br />CrappieManNate @ gmail . com
Drowned Rat
Re: Cummins VT903
I know that motor inside and out. I worked on them for 7 years in the Coast Guard. What do you want to know?<br /><br />Big and HEAVY Pushrod V-8 <br />903 CID<br />318 shaft horsepower with turbo<br />285 hp without.<br />Very easy to work on, they're older motors so most if not all have been rebuilt many times.<br />The VT903M was made specifically for Marine use. If it doesn't have the M on the end then it was retrofitted probably from a bus engine or tractor, I would be careful if that's the case.<br /><br />Let me know if I can answer any specific questions.
Peter J Fraser
Re: Cummins VT903
Also used in class 8 trucks for many years. 70's thro 80's from memory.<br />I used to buy them out of Texas from a truck dismantler and bring them to NZ.<br />They were popular here as they were 350 hp in truck application and International Harvester sold a lot of trucks here that used a 903 non turbo rated at 325 hp but with quite a drop in torque from the 903T.<br />Pretty strong engine either way.<br /><br />Peter
