CRYSLER 115 oil mixture
jdiakiw
just bought a old Crysler 115 boat and motor model # 1159B8B<br /><br />Where can I find the right oil mixture?
eurolarva
Re: CRYSLER 115 oil mixture
The correct mixture is 50 to 1. If it has not been run for over a year you may want to burn 6 gallons of gas mixed 24 to 1.
jdiakiw
thanks . what is the reason why a 24 to 1 mixture should be used with 6 gallons after a year of use ?
eurolarva
When a motor has not been run for a long period of time and was not fogged you should treat it like a rebuilt engine. The higher oil mixture is to make sure plenty of lubrication gets in there.
