oldsalty24
- May 9, 2008
- 10
I have a 33' Egg Harbor with twin freshwater cooled 454's. I have recently replaced both thermostats [160 degree], and both raw water pump impellers. The pumps are good with no wobble. The coolant is filled. This work did nothing to fix my problem. The Starboard engine and port engine run at 160 or less when running under 1800 rpms. When over 3000, the starboard starts creeping up to 195 and possibly higher. I bought a temperature sensing gun and went down in the engine room while running, heres what I found - At 1500 rpms the gun was put on the risers port engine- 124/118 - and starboard engine- 157/121. at 3000 it read port - 160/140 and std - 160/170 and on the manifold it was port - 171/175 and starboard was 195/187. and at the thermostat cover -port -160 and starboard was 185. Do I need risers, a new freshwater pump or what? Thanks for any help, Jon
