Crownline battery discharging on 2 Crownlines
Fourty6
Crownline, on two Crownline boats, my batteries discharge after sitting for a couple months. Battery switches off. I am in the process of trouble shooting with a current meter but I was wondering if anyone has run across this before.
GA_Boater
Welcome aboard.
How old are the batteries? Were they fully charged before sitting for a couple of months.
tpenfield
The radio 'keep alive' will draw some current. Also if the bilge pump is going on occasionally, it will tend to drain a battery. See what your current draw is with everything turned off (main battery switch off, etc).
Folks generally either remove the battery for winter layup, or use a trickle charger to keep then 'alive'.
Batteries self discharge 4% per week
Any electronics connected? As indicated prior, the radio electronics will draw enough to kill batteries in about 4-6 weeks
Your talking months. Buy a battery maintainer
dingbat
At a room temperature of 20°C (68°F), the self-discharge is roughly 3% per month and the battery can theoretically be stored of 12 months without recharge.
With a warm temperature of 30°C (86°F), the self-discharge increases and a recharge will be needed after 6 months.
I keep my rooms at 76 degrees..... cant afford to go any colder
at 80 degrees its 4%, at 90% is closer to 6%.
dingbat
Yes. Per month, not per week as noted above.
My batteries get charged when I put it to bed in December. No problem starting the engine in mid March.
Gets a tad cooler than 80 here in the winter ;)
Averages 43/25 in January.
