Please don't groan....I'm trying to rebuild my carbs and adjust my jet sizes using primarily my pile of spare parts, but I have a few questions:
Background: I have been running a pair of 1 5/16 throat carbs (1982 generation) w/ #36 (throat jets), and #29 and #67 (bowl jets) for a couple years on my rebuilt bubbleback V4 with a '85-'87 era ignition system and approx 100PSI/cylinder. With those jets it seems to run great at cruising/planing speed, but rich (very smokey with LOTS of unburned fuel in the exhuast) at idle, and the spark plugs seem to agree. A day out cruising and the plug insulators are somewhat chocolatey like they're supposed to be, while a day of idling or trolling and they're pretty wet and black. wanted to try trading out some of the jets to see if I could lean out the idle mixture just a bit and found out the hard way that I over-tightened the #67 jets in the float bowl last time I serviced the carbs. Needless to say, those jets are stripped and the bowls are ruined. Herein lie my questions.
1) I have two sets of spare carbs w/ 1 3/16 throats from the same generation crossflow. The float bowls have different stamped part numbers but look identical visually. Can anyone tell me if they are interchangeable with the bowls from the 1 5/16 carbs or if the air/fuel ports are different somehow, irrespective of jets?
2) My original goal was to replace the jets I had been running with the standard 115 HP jets from that era (27, 34, 60). Will the 1 5/16 throat be too large for the reduced jet sizes/fuel input and therefore make the engine run too lean?
3) Ultimately, with the stated compression, two different carb sizes, and multiple jet sizes I have on hand, does anyone have a specific recommendation for plugs, jets, and carb throat combination? I'd like to make sure this engine is tuned right and running efficiently.
4) For my own own reference, what throat size carb historically went with what HP V4 engine?
Thanks for any input,
Ryan
Ryan
