FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Yes it matters.usually they are marked top or something similar.
With the plugs out ground one plug turn till a piston is near top dead center snap the flywheel by hand through the tdc stroke should get a spark.
you'll have to test both wires to find the match.
On that small motor you should be able to rotate it back and forth through the tdc stroke.
Most manufacturers put a small band, marked with TOP, around the plug that fires the top cylinder...sometimes they get pulled off, I have found others by simply cleaning the dirty wires.
