New to the forum here and need some advice.
I have a 1976 40 hp Johnson (model 40r76). The coil snapped inside the flywheel and destroyed the armature plate. The armature plate on it is stamped 580360.
I found a 1970 Johnson 40 Hp armature plate from model 40 ES. armature plate stamped 580867
Will this plate work on my motor? also, how do u set the timing on these when replacing the flywheel?
Any advice is much appreciated.
