Crooked Trailer Tire? Bent Axle?
Goldsmithnb
I think the axle is bent on my trailer. I had a blowout on the passenger side at 65 mph on the highway...drove for a hundred yards to get off the road on a shredded tire. Ever since then, the driver side has been "crooked" (toe out, if i understand the terminology?). I have been reading about this but want to get some opinions on here.
Safe to drive? Need a new axle?
rallyart
An alignment shop will often 'bend' a trailer axle to get the tire in to spec. It is hard to tell from the picture but I am assuming that it is taken from the front looking back. Is the tire feathered? That is, are one edge of the tire tread ribs wearing quickly and the other edge seems flared up. It looks like the outside edge of the ribs in the photo are worn more, but I might be mistaken. If so then it has toe in. Run a tape measure across the front from the center rib on one side to the center rib on the other. Do the same with the back. If the front is a shorter distance than the back you have toe in. Camber can also be affected. That is the tilt of the tire.
Any alignment problem will wear tires quickly and increase the chance of a blowout. If you have toe out you are towing an unstable trailer and it is more dangerous and unpredictable. The cost of an alignment is less than the cost of replacing an axle and less than the cost of new tires. If the axle has other problems too, then replacement might be a good idea.
SOG3
The spindle appears to be partially broke away from the axle ,possibly bad weld .
SOG3
Just noticed you have a torsion axle if I'm not mistaken ,and the rubber may be worn.
jimmbo
Goldsmithnb
Thank you for all the responses - I will explore the spindle broken away suggestion
gm280
Sure looks like the spindle is coming loose from the axle. I would have the looked at and fixed before doing any more trailering with a boat. I would also check and repack the wheel bearings on both side too! JMHO
