Crazzy prop
scooter4n
I have 18' chaparral bow rider with 3.0 Mercruiser I just got.
It has aluminum prop with crazzzy size: 15 1/2 x 41 is this possible???
I get 4000PRM at WOT doing 35mi/h GPS with 4 ppl in boat.
WillyBWright
Re: Crazzy prop
No that's not possible. 14-1/2 x 21 would sound more in the ballpark. I'd think a 17p or 19p might be more appropriate to get the RPMs up, 4000 is too low.
scooter4n
Re: Crazzy prop
I want to upgrade. I want to go with SS prop. what size should I go with. I usually have 4 or more people in the boat. Im not looking for speed, I want more just at take off, but little speed wont's heart too, but more at the buttome end.
Please recommend.
Thanks
P.S. I'll have picture of the numbers from the prep posted later.
scooter4n
Re: Crazzy prop
I'm thinking to get:
Stainless 4 blade 14x20
what you all think?
(18' bowrider 1990 3.0 Mercruiser)
Thanks
tommays
Re: Crazzy prop
It really depends on your goal mine was to get better LOW speed performance and the best fuel economy in the 25 MPH range on long trips
If water skiing was what you want to do it would be the wrong pick
I run at 14 X20 4 blade ALU prop on a 19' 3.0 powered boat
It is the BIGGEST prop i would even consider and the extra bite of and SS one might be a bit much and result in to low of a WOT which should be in the 4600 to 4800 RPM range
Tommays
scooter4n
Re: Crazzy prop
I don't do any water sports.
mostly cursing, but I want to go fast from 0 and up. maybe top speed around 40mi/h and around 4500RPM
what should I go with then? Defiantly SS.
tommays
Re: Crazzy prop
Really need to know what is on there NOW as if it is a 21" :confused:
The 4 blade is going to give away top speed in exchange for low speed performance
It is hard to tell from here if it is even running good recent service ect
Tommays
scooter4n
Re: Crazzy prop
now I have 15 1/2 by and there is 21 stamped over 19, so hard to tell is it is 19 or 21, but looking at the low rpm's at WOT I bet this is 21.
I don't really care about top speed, I like more just at the low end, and mid range, and be able to get to 40 mi/h as well.
Crownie2
Re: Crazzy prop
I guess you are just going to have to try one or the other. Know any dealers who will allow a test?
Lot's of good info in those posts - as you can see there are those who prefer 4 blades on their boats and those who don't. I think for your boat I am in the three blade camp. I guess you will have to try them and decide for yourself...
Bob
