Crazy Cigerette Lighter
Boss Hawg
I put a new Lighter in my boat & wired it direct to my cranking battery - When i push it in with everything shut off (key off) my gas gage goes to full :confused:
With engine running it makes the gage move a little also, soon as it pops out gas gage retuns to proper position -------
Ideas? Would it just be better to run it off my trolling battery?
j_martin
Re: Crazy Cigerette Lighter
It shouldn't affect your gauges at all. You have a serious wiring fault somewhere, probably a ground.
Find it before it strands you.
hope it helps
John
Silvertip
Honorary Supreme Mariner
What did you ground the shell of the ligher to? And you did connect the center terminal to the POS battery post -- correct?.
Boss Hawg
Grounded to a grounding spot on the fuse panel & ran hot to battery -
Its a 1987 Starcraft fiberglass bassboat-
Silvertip
I don't think you have the ground on the lighter connected to ground on the fuse panel. I feel you have it on a non-ground position so when you punch the lighter you are actually feeding the gauge. Better check the ground connection.
ridefst
Yeah, there's not often a "grounding spot" on the fuse panel. It's generally all positive voltage.
Try running a ground straight back to the neg battery terminal, since a cig lighter can often draw quite a bit of current (depending what you plug into it), direct wiring (with some sort of fuse in the pos wire) is probably the best bet.
Boss Hawg
Thanks, i'll keep it simple & safe & just run both wires to trolling motor battery :)
flargin
if you do have a fuse panel with a ground section... run the ground back to the battery and connect it to the ground section. You existing ground line is falty, and this would be just the start of your problems. This would likely prevent other problems.
Silvertip
Most modern fuse panels do indeed have a ground bus on them but some folks simply don't understand that or understand a little but still make incorrect connections.
Boss Hawg
That was it :cool:
All working great now :D
Thanks to all!!
flargin
Great to hear.
You may want to spend a few minutes to figure out what happened to the ground that is not working.
Boss Hawg
Great to hear.
Most defintely up on my list ;)
The wireing was (still is) the only real PIA in this new to me boat :rolleyes:
