Crankshaft damage
Steveng
Attached is a picture of the crankshaft from my 91 Jphnson 70 hp. It was overheated and shows a blueing on the rod journals. Can this be polished out, or do I need to replace the crankshaft?
Thanks to all, Steve
Daviet
Re: Crankshaft damage
Did it get hot enough to do any piston or cylinder damage? By what I can see in the picture, I would try to polish it and then see what it looks like.
wilde1j
If it got that hot, I would be concerned about journal hardness. It may be possible to heat treat it by a good shop. I would measure it first to see if all surfaces are within tolerances.
Faztbullet
If there is no material transfer it should polish, if you need it polished pm me...
Steveng
It destroyed number two piston to the point I am boreing the cylinder and replacing all bearings etc.
