Cranks but won't Start
godfreyind
Okay I'm not motor jockey but I'm not an idiot either, or maybe I am. Im stumped. Motor cranks like its going to the races but won't turn over. No sputter, backfire, spit choke or anything. Replaced the CD unit since there was not spark. New plugs. checked all wiring, grounds, neutral safety switch. Good spark at the plugs. fuel pump functioning, Clean gas, Gas in carb bowls but no turn over. Circuit breaker good, regulator good, electric choke operating. Spark plugs don't get fouled or soaked in gas. If anyone has ideas please let me know. Prefer not to repower the boat but don't know what else to do soon, None of the marinas in my area will touch a Chrysler. Motor was running fine and just quit when I was brining it in to dock was never able to atsrt it again. did put a new battery in. Needed it anyway. No dead short. Tested all circuits power to everything. Overtemperature sensor good. not that the motor won't start with that bad. any ideas or hel would be greatly apprecaited
Thanks
godfreyind:confused:
Jeremy90bay
Re: Cranks but won't Start
What kind of motor is it. yr, size, code?
Jeremy90bay
Im not sure how to jump yours, but there is away to bybass the switch to test it.
john from md
You may have spun your flywheel and moved the timing off.
Pull the nut on the flywheel and see if you can tell if the flywheel is still lined up with the key in the crankshaft. If it is, do the following.
Pull the plugs, ground the plug wires and jumper the neutral safety switch. Put a timing light on the engine and see what you have at idle. It should be
0~-2 degress.
Next, put the trottle in WOT and put the timing light on it again. It should be 30 to 32 degrees.
Check back with the results.
John
