BigNiner19
Thread starter- Joined
- Jul 1, 2006
- 234
There is a lot of play on my spark lever its so bad that when I bring the control back to nuetral, the spark lever wont always come back to it position making the motor have higher rpms when trying to idle. Usually it will also keep rising in rpms too.
I have come to the conclusion that the 2 bushings on the crankcase are worn out. The part numbers are 0314002 and 0314003. One is for the spark lever, but both bushings are on the inside of the bolt. Anyone ever replace these bushings before? is it common? Mine are definitely worn out it seems.
The motor is a 1988ish-1992ish Johnson 60HP.
