Crank shaft boot
Jyocum12
I have a 87' mercruiser 120 and i noticed theres a rubber boot on the main drive shaft going to the outdrive that is dry rotting. Is this a problem or is it just to cover the shaft. I talked to some guys at work and they said they had a boot that went bad on the outdrive and it almost flooded there boat. Any ideas or thoughts would be helpful.
thanks
Bt Doctur
Re: Crank shaft boot
If you plan on using it as a planter, then it not aproblem.
If you plan on putting in the water, then yes it`s a problem because it will let water in and sink the boat.
Jyocum12
Thanks, do you know what it is called and is it expensive to get fixed.
Jyocum12
Does anyone know what this part is called and how hard it is to replace.
Fishermark
It's called a driveshaft bellows. It is not especially difficult, but I wouldn't classify it as easy for someone who has never done one.
I don't have a link to the OEM manual, which would be helpful for you, but here is a page that will probably help:
http://www.mercstuff.com/howdoi.htm
Tjdunklee
I just finished replacing the bellows (shift and crankshaft/u-joint) on my Alpha 1 outdrive. It wasn't too hard, just time consuming. Follow the directions in the manual very carefully and take your time! Do it right the first time and you will thank yourself later! I also did the lower shift cable as long as I was taking stuff apart and the boat now shifts like a dream.
Fishermark
I don't think I've ever gone into a well stocked marine store that didn't have one one the shelf - many times even out with the "over the counter" stuff. Every web site that sells marine stuff will have what you need. Take your pick! ;)
