Re: Crack in transom seal, is there a preffered way to patch?
:joyous:
What is the difference between mechanical and hydro mechanical?
As far as the boot is concerned, there is no difference, but for future reference, the hydo-mech uses a hydraulic shift assist plunger in the lower gear case where as the mechanical drive is just that with an electronic shift interrupt system that momentarily stumbles the ignition.
Here is what the lower for a hydro-mechanical drive looks like:
And here is what the lower for a full mechanical looks like:
Notice that the full-mech has a spot for a zink anode.
In addition to that, the full mechanical will have the switches for the shift interrupt attached to the shift converter housing as such:
For the correct boot, go here:
OMC Boat Motor Parts & Outdrive Parts at MarineEngine.com After you put in your engine specs, go to "intermediate housing" and then down to #89. The one you want is priced at $134.55. There might be better prices for it somewhere else but they wont be by much and probably not worth the time to look around. But I always encourage smart online shopping.
