Covering 3M 5200 with Gluv It
Pokaseedes
I need some advice please, we recently bought a boat (Bass Boat--so we can't get to the rivets from the inside) from an individual that was supposed to be fine, everything worked, no leaks, and guaranteed. You guessed it, we've gone thru money and h*^*$# just to get it to run, still working on repairing and replacing the perfect things, plus it leaks like a sieve. :eek:
It was leaking 8-10 gals. every 10-15 min., I think that amount was critical, so the work and decisions began.
We've worked for two weeks, trying to stop the leaking, thank goodness for this forum, I read everything I could find about leaking aluminum riveted boats. We cleaned off the center strip and rivets, and used 3M 5200 the entire length, my question is, we plan on cleaning off the remaining bottom (not sides) and using gluv it, will the 3M 5200 and gluv it be compatible or should we avoid the center area that has the 3M 5200.
I've also read that taking off the oxidation isn't a good idea, our boat has a lot of plain 'ole dirt, I want the gluv it, to adhere and I think it needs a light sanding. A local boater told us to use Sno Bowl toliet bowl cleaner. Your ideas about the dirt (remove or leave) would be much appreciated.
Please be kind with your answers, this is my first post.
TIA Pokaseedes
QuadManiac
Re: Covering 3M 5200 with Gluv It
Don't have an answer, but thot I'd 'bump' your post to see if it gets more attention.
Good Luck!
Pokaseedes
Thanks for your reply, I was beginning to get slightly discouraged, as you can probably tell from my second post. Thanks again.
steelespike
It's amazing how many folks come on here after buying without a test ride or at least a motor test run.By the way what boat/motor combo do we have here?
I have heard of putting paint on truck bed liner on both the inside or outside of a boat.I remember the outside results were good with it holding up well
under severe abuse.running over logs,beaching on gravel bottoms etc.
But preperation is important.And I don't know about the 5200.
This should be done after tightening the rivets.
With it carefully supported on the trailer add water (BE CAREFUL WATER IS REALLY HEAVY AND COULD SUDDENLY THROW OFF THE BALACE ON THE TRAILER).to see where the leaks are.You may just have a few critical leaks.It's important to find them.If they are cracks, if you let them go they might split with sudden disaster.
While it is a pain you could remove the deck/floor to get underneath.
You and a buddy could tighten the rivets with a couple of hammers using one to back up while carefully rapping on the other end.
