Coupler grease????
edwardh1
Does anyone use either (1) gimbal grease or (2) HP trailer wheel bearing grease on the splines in the engine to sterndrive coupler?<br />I hate to have to buy yet a third type of grease from merc cruiser. <br /><br />Seems the gimbal grease and the trailer wheel bearings "see" heavier duty than splines and that either of those greases would do fine.
burp
Re: Coupler grease????
Mercruiser Quicksilver Engine Coupler Spline Grease part number 92-802869A1. It is different grease than the gimbal bearing grease.
MrBill
There was a recent thread in "trailers" discussing grease for bearings, and if "better" grease should be used for trailer bearings. It is important to understand that grease is formulated for specific conditions, short-term every grease lubricates, long-term it may not provide the protection intended.<br /><br />Grease is comprised of a base oil with a thickening agent that prevents evaporation of the oil which increases its lubricating life span (how long it is effective at providing lubrication). Additives also improve corrosion protection, resistance, and reduce oxidation. Grease is also formulated for specific temperature ranges...for instance, bearing grease will withstand the high temps that tires and bearing friction generate, rather than liquify. Although other greases may have better lubricating qualities under room temp conditions, they probably don't under high temp.<br /><br />Grease is used for low torque applications, high speed or where circulation of the lubricant to provide cooling is NOT required. Greases have different types of base oils (such as petroleum, synthetic, silicone, etc.), various thickeners such as lithium, sodium or urea bases, working temperature ranges and dropping points (temperature at which it liquifies). They also have channeling or non-channeling properties. Channeling refers to whether the grease stays in place when displaced by a moving part like a bearing, non-channeling grease migrates back into a cavity or raceway.<br /><br />So....there's more to grease than most people want to know. Why risk the expense and inconvenience of early failure on an expensive piece of equipment for $8 ?
crazy charlie
I have to agree with Mr Bill,although every boat I have ever owned with i/o I have used the green marine trailer bearing grease for everything.Splines,ujoints,gimbal,trim ,shift arm,propeller shaft,impeller install---everything without a single failure.I have even used it for what it calls for,trailer wheel bearings.I also put a generous amount between the shift bellows and the drive shaft bellows and the exhaust bellows to prevent or minimize chaffing between the bellows.Charlie
Boomyal
I know this is not constructive, but boy am I sure glad I have an OMC 800 o/d. Don't have to worry about any of that stuff. Wish they still made them. I have 22 y/o balldrive gears with no sign of wear. In addition to all of the above they have a tighter turning radius and raise out of the water quicker and higher.
crazy charlie
Hey Boomyal is that the outdrive that when tilted full up and with the right prop can turn the boat into an Osprey Helicopter?????Charlie
Boomyal
dat's da one CC. But the balldrive gear would break in mid flight sendin ya down in flames ;)
edwardh1
the real question is what does a self employed boat mechanic do - does he carry around 3 grease guns?<br />one with trailer bearing grease, one with gimbal grease, and one with spline grease?<br />I bet most of them do not.<br />Changing grease is too messy and time consuming.
rodbolt
hello<br /> edwardh1<br /> yep as a matter of fact I do. its a bummer but if something fails and people die the lawyers would blame improper greasing and guess who would be holding the bag. my insurance is almost 10 k a year. and in 12 years I have never had a claim. knock knock. <br /><br /> wow broken parts??? down in flames??? sounds like the real osprey :) :) :)
tylerin
edwardh1, Whatever grease you decide on. Be careful how much grease you use, or it will be difficult to slide the spline shaft into the coupler.
seahorse5
Rodbolt is correct, a competent tech will carry around the correct lubes according to the manufacturer's recommendation. The "one size fits all" grease is normally, used by shade-tree, uneducated, and uncaring mechanics.
edwardh1
Thanks - i did not expect a one grease fits all, but thought there might be a "two greases fit all" solution.<br /><br />like maybe gimbal grease and wheel bearing grease
Lou C
Just get a couple of grease guns, they are pretty cheap. I have a big one for stuff that is easy to get at, and a little one for tough to get at stuff (steering ram grease fitting).
