Couple ?s on a 175HP Johnson outboard
Status
Not open for further replies.
thebrain
Banned
Couple ?s on a Johnson outboard
1.is this a long shaft 25”?
2.is this a 4 stroke or 2 stroke type engine
3.the jack plate it’s attached to is it hydrolic? There is a guage on the dash trim up, or on.
4.this is a 2003 year model will it be fuel injected?
Thanks for advice
jbcurt00
Not enough info TB
Long shafts are 20in not 25
Extra long shafts are 25in.
Honorary Supreme Mariner
Post a model # first.-------As it is you will get no answers.
thebrain
Banned
woops my bad I thought I uploaded the image
also are the white Johnsons saltwater types?
bob johnson
a picture does not help completely..... you need to go to the tag on the swivel bracket....... they had some "P" models.....not sure what that designates...
bob
bob johnson
I think the four stroke Johnsons only went up to 140 hp that year....so you have a 2 stroke.... and I don't THINK they made a direct injection model in a Johnson in 2003..... so it is most likely carbed
Silvertip
The trim gauge is for the engine itself. The jack plate looks hydraulic and would have a separate switch to raise and lower it. The simple way to tell if it's hydraulic or not is to look for a fluid reservoir and perhaps hydraulic and electrical lines going to it. If the engine is a two stroke it will have a separate oil reservoir at the stern (inside) the boat. A hose from that reservoir goes to the engine.
jbcurt00
Need to start going out and SEEING and HEARING some motors run.
Online searches and asking questions remotely via the internet isnt going to help you in your search for just the right motor any more then it did for a boat. Might even take longer then it did to find the right boat.
Add in sellers that dont put enough info in their ads, or answer questions and it becomes even harder.
Its not simply a wasted trip to drive over an hour and not buy the motor, its furthering your education about motors: what to look for in an ad and hands on to reduce the time spent considering motors that arent a great fit for you, your project and your budget.
Rarely is a low cost 'deal' on a motor going to be any more of a deal then cheap boats are. Projects can be more expensive to rehab.
In Florida, what are the chances motors have been run in the salt, and meticulously flushed inside and out after every trip?
Pix on the internet wont tell the whole story and many (most?) sellers probably wont be 100% honest either. Esp CL/ebay outboard sellers. Heck, this ones a 12+yr old motor, is the current owner the original owner? What did the original owner do or not do to it?
jimmbo
That looks like a 2003 Ficht. Myself, I wouldn't walk away from it, I would RUN!!! Yes it is a Fuel injected 2 stroke, 1st generation Direct injection. Lots were sold, don't see too many on the water anymore. These engines are what put OMC out of business
boobie
Maybe I missed it but we still need a model # off of the motor ???
thebrain
Banned
my bad this is actually a 2004 year model here's some more images of engine
is the jack plate controlled w/ a foot pedal there is a aluimin hot foot apparently this boat has been used in saltwater the hot foot is correded
thebrain
Banned
my bad this is actually a 2004 year model here's some more images of engine so in 2005 they started w/ the Etecs?
jimmbo
I was wrong. It is not a Ficht, nor is it an E-tec. it is a carbed motor. Man I hate it when I am wrong. A model number would be a good start. Johnson did make a 175 with carbs that year(2003)
jimmbo
Oh yeah. As engines go, these were very good engines.
thebrain
Banned
sorry model is unavailable right now.
I thought I wanted a newer rude like a Etec then thought someone would want to steal the boat for the newer engine I also thought the same about a modern 4 stroke.
I also considered maintainance on a fuel injected engine (which I was under the impression would be less since carbs aren't rebuilt every couple of years) a friend has a newer Honda 75HP 4 stroke he told me he had to have his fuel injectors replaced, water pump lower seals couple other small things bill from shop was $1200. he said he wished he'd stay w/ a 2 stroke carbed.
either way I end up there are pros and cons.
if I go carbed I'll have to learn how to rebuild one, I meet a marine mechanic last trip to beach and he says he wouldn't mind showing me during the first carb rebuild.
I'll know in a few hours what engine I get.
TB
Yes, modern 4 strokes run really nice , quiet and smooth.----Some folks accept that and are prepared to pay extra for maintenance and cost of ownership.---No different than luxury cars , just cost more per mile to own / operate !!!
boobie
Sorry, but without a model # I can't help you out. Not intelligently anyway !!
Status
