86IROC
- Apr 5, 2010
- 89
1981 evo 70 hp.
Had the boat out yesterday and picked up some eel grass apparently. I make a habit of checking the "pee stream" to make sure it's pumping.
I noticed it wasn't and what looked like steam around the back of the engine so I immediately throttled it back and shut it off. I waited about 15 seconds and tried to start it. It started ( and was pumping) but quit when I put it in gear.
I started it again and idled it up with the fast idle and let it run for a few minutes.
Eventually it idled when I put it in gear and seemed to work great after that.
When I got it home it started and idled normally when I flushed it.
I pulled the cover off to see if there was anything obvious that might have caused this. I noticed a "sensor" in the cylinder head by the thermostat housing with a wire that goes to the wiring harness by the coils.
Is this some type of safety feature that cuts power to the coils if the motor over heats?
the other "stupid" question is..what is the friction adjustment on my remote throttle control for? :redface:
