Re: Counter Rotating a motor.
The pinion, forward, and reverse gear teeth are angled for quiet operation and can handle higher torque loads. The angle forces the pinion gear up against it's large roller thrust bearing. Forward gear is forced agaist a full diameter thrust bearing, and reverse gear has a small diameter needle bearing to take its thrust. whenever an outboard is running, all 3 of the gears are turning. Since in most instances, reverse in not used for any long periods of time and not at full throttle, there is no need for a big thrust bearing in a regular gearcase. <br /><br />Stop by a dealer and ask to see a forward bearing with its good sized rollers and about 4" in diameter and compare it to the 2" diameter reverse bearing with its small needle bearings.<br /><br />A counter-rotation gearcase uses a tapered roller bearing in the aft gear that is encased and also uses a 2 piece prop shaft, since the propshaft thrust turning the propeller is in the opposite direction of the back gear thrust during normal operation.
