Couldn't believe it..........
FreeBeeTony
Went fishing this moring, the bay was like glass. Drifted the inlet then headed outside, the ocean was beautiful. Caught 5 or 6 short fluke then decided to head back in. Ran all the way in ~3500RPM.........engine sounds great!!
Coming around a sandbar (near Captree for all you south shore LI people) and felt like I hit bottom. Saw 2 boats hit it earlier in the morning when I was heading out.........my depth finder said I was in 15' of water........I'm thinking what the hell happened? Engine was still running........I had pulled the throttle back into neutral as soon as "it" happened. All gauges were fine, put it back into gear and started to go........soon as I got up to 200RPM the engine rev'd out...........now I'm thinking either a spun prop or engine coupler. I replace both when I installed the Rapido Vortec last fall.
I make it back to the slip and my son meets me there with a spare prop, I remove the prop and it looks fine (has the plastic insert for the hub). When I removed the prop I noticed a few weeds...........could it have been weeds causing cavitation??
I reinstall the prop and my son and I head back to the bay for a test drive......got up on plane and hit 4000RPM w/o a problem........!!!!!!
I must have picked up some weeds coming around that sandbar and it cavitated.....I have had this problem before but it just didn't occur to me this time.
Needless to say I was quite relieved to say the least............when I saw the prop was OK I was invisioning pulling the engine to replace the coupler.
Just thought I'd share this..........
FreeBeeTony
Re: Couldn't believe it..........
Just thought I'd bump this.............might be good for a laugh.
Ayuh,.... I Am...... :D
My area is kinda weedy,.... A quick jab in reverse usually Fixes the Problem.....
And,...
I've never hit a clump of Weeds at speed that was at All noticeable.....
Sounds like you had pretty much a Great day on the Water,.......;)
FreeBeeTony
Belive it or not I know all about the revsee trick.......been doing it since I was a clammer in college..........just didn't think that's what it was.......
I was ready to pull the engine thinking it was the coupler!!!!!
Glad I was wrong.
FreeBeeTony
Went out today..........just to make sure............:)
Ran great...........engine is really running nice...........was cruising at 30MPH at 3600RPM............not bad for a 24' 4200lb boat............
tommays
I find the built in Pitot tube on the GEN II to be a good GOOP dector and allways reverse when the speedo dies to stop any waterpump issues ;)
