Re: Could someone help me regarding Yamaha Breakin Tips?
Here ya go. Right out of my 2-stroke Yamaha manual.<br /><br />"Break-in procedure: Your new engine requires a period of break-in to allow mating surfaces of moving parts to wear-in evenly and thus ensure proper performance and longer engine life.<br /><br />Mixing ratio: Oil/Gasoline 1:50<br /><br />CAUTION:<br /><br />Be sure to use a premix fuel during a break-in period.<br /><br />Break in time: 10 hours<br /><br />1) Run the engine at trolling speeds (the lowest possible speed) for the first 10 minutes.<br /><br />2) With an easy planing boat, bring it into the planing position; then, immediately reduce the throttle to approximately 3,000 rpm (one-half throttle), continue running at this throttle setting for 50 minutes.<br /><br />3) Bring the boat into the planing state and reduce throttle to 4000 rpm or three-quarter throttle (approximate) while maintaining planing. continue running at this throttle setting for one (1) hour.<br /><br />NOTE: Run full throttle for approximately one (1) out of every 10 minutes.<br /><br />4) for the next eight (8) hours, avoid continuous full throttle operation for more than five 95) minutes.<br /><br />5) After the first 10 hours, use straight gasoline for normal operation of the Precision blend system."
