Could it be the headgasket? Overheating symptoms.
rando1201
HI everyone,
I just bought a used evinrude 2 stroke 8, its a 1990 year model. evinrude Model# E8RLESR. I think that it is overheating.
There is warm water coming from telltale.
The exhaust 90 degree tubing under engine cover is spitting a little bit of water and what seems to be gas or oil because it speckles the water.
The lower end gets pretty hot to the touch.
Seems to have white smoke coming out like it has to much oil in the pre mix.
The tell tale water streams very well but eventually gets warm.
I took it out the other day, it runs well, but on my way out of the harbor it seemed to loose some power then make a clicking sound.
Later that day I let it run in gear, and in neutral for over 30 minutes. And it still ran great, streamed lots of water from tell tale. But the water got warm, not hot to the touch.
I messed up and left the motor down in the water for over a week, after that is when the problem started happening or at least when I noticed it.
I have taken it out several times before, and I just have the weird premonition that something is not right.
I use it on a 26 ft sailboat. And I dont want to get towed in again. Already happened twice with my last outboard. So if you guy think it may be a head gasket.
Thanks so much you will be hearing alot more from me, i got a free boat, I have been restoring it for the last 6 months with a low budget. 1964 Fisher flyer del mar.
Joe Reeves
Blue smoke= Oil....... White smoke= Water
Remove spark plugs and observe their appearance.
Check the compression. What is the psi reading of the individual cylinders?
Low uneven compression... or... low but perfectly even compression? = Suspect damaged head gasket.
Let is know what you find.
