Cost vs. benefit of adding tach & temp gauges
jtexas
I would appreciate any opinions on the usefulness of a temp gauge on a 1980 70hp evinrude. This motor's been in the family about 3 years (I've had it couple months) & has outstanding operating & mtx history over that time. Just don't want to blow an engine for want of a few bucks worth of accessories. I'm also wondering how close I'm getting to the end of the lifespan of this puppy.<br /><br />Don't know if a tach would be useful but I'd like one anyway just because. Anybody know how much trouble it would be for a reasonably competent do-it-yerselfer?<br /><br />Any opinions?<br /><br />thanks very much,<br />jtw
Hooty
Re: Cost vs. benefit of adding tach & temp gauges
Yo JT,<br />I personally, prefer a water pressure gauge to a temp gauge but temp gauges are good. Either one gives you insight into the cooling of the engine before the high temp horn goes off, which in some instances is just to late. To me, a tach and a speedo are a must. Using them is the only way you can determine if the boat and engine are set up correctly.<br />c/6<br />Hooty
walleyehed
I'll agree with Hooty, mostly on the tach though........that is basically the only gauge that tells you how hard, (or easy-no-load) the engine is working- the best investment you could make........ :)
backdraft
Jtexas, gauges make the whole ride fun. I like to have a tach, a voltmeter, a water pressure gauge and a temperature gauge . The cost is neglegible compared to a meltdown. From this I can determine the condition of the engine and the operating systems easily.nevjb
rodbolt
Hello<br /> the only gauge that is usefull is a tach. a water pressure gauge is a close second. a temp gauge totally useless. voltmeter is ok but if the tach works odds are its charching. tach failure is one of the first symtoms of charging system failure. most the customers that call me and I ask what did the temp gauge read when it died say MMM I did not look at it/. I have seen t-stats on v engines fail and the head that had the senser never got hot and the other bank melted pistons. hekk I have looked down before and thought wow I wonder how long the gauge has been pegged like that. give me audible alarms anytime. but that is just my opinion<br /> Good luck and keep posting
