Re: Cost for mechanic to replace ESA.. OMC
Ynots, with this setup and conversion I have I have had my share of ESA issues. The jumper your mechanic is referring to is the jumper to connect the overstroke switch. It is not needed and should be bypassed for the new recommended ESA. The CDI/Rapair I recommended is a drop in replacement for the original OMC ESA with the overstroke switch intact. I did both replacements and when I went to the CDI ESA I had to reconnect the overstroke switch. The CDI part will then be readily compatible when you are ready to go back to pertonics and technology.
