orlandoclippertim
Thread starter- Joined
- Jun 2, 2011
- 106
I have a early 1960's evinrude 28 horse 2 cyl. The lower cylinder ( I think ) is stuck from possibly a bad head gasket - water in cylinsers.
I have been soaking clys in PB for 3 weeks with no luck. Removed head bolts to remove head. The bolt pattern is shaped like a pea-nut.
all the preeimeter ones came out OK but all had some white corrosion and a little rust. There are 2 in the "waist" of the pea-nut whichseem to be stuck MUCH harder. One of these I have acess to the area where the threads are - that is the back side of the threaded area is open. I have been shooting PB in there for about a week. No perceptable letup in torque. The other stuck bolt is in the area behind the water side plate cover.
I have taken most of the little #10 side plate bolts off thinking I might have acess to the bottom of the head bolt from in there maybe. However
2 of the #10 cover bolts are also stuck. Tried tapping with little hammer, heating , PB over and over.
The head bolts appear to be 5/16 grade 8. I can feel I am not moving the bolt- only "springing" the shank. I don't want to risk any more torque than I have tried. Will an impact type driver be OK - the kind you hit with a hammer ? I have tried a pneumatic air hammer without much effect.
I used small propane to heat head bolts. Lots of metal to soak up heat. May have to go to oxy-acet. to get bolt hot.
I have browsed search results but found nothing earth shattering in the way of ideas.
Any advice ?
Tim
Any advice ?
Tim
