docoakley01
Thread starter- Joined
- May 24, 2009
- 11
Hello
I have a 99 182 Crownline with a 190 hp 4.3 Merc Alpha one outdrive. The boat came to me with an aluminum 3 blade 14 inch 23 pitch prop which I promptly gouged out on my maiden voyage. The prop has a bronze splined insert, if that helps with the style. I have been reading up on props a bit, and a 23 pitch on a V6 might not be the correct prop for this boat? I find WOT to be about 5200 RPM, but can't really provide a top speed as I did not run it that high prior to my problems. I need a new prop (or at least a couple of used ones at this rate) but don't want to replace it with the same if it was not correct to begin with. I have my transom ID, etc if it might help.
Thanks for any advice you can give.
