correct float bowl identification to replace plastic float bowl Johnson vro 90
Can1
hello all,
first time poster here so bear with me. i have leaky plastic float bowls on my 94 vro 90 model j90tlerc serial # G 03594742.
I understand that it is a known issue and there were replaced with Aluminum bowls but these are no longer available. I picked up 2 complete used carbs from a VRO for the float bowls. i want to tranfer the aluminum bowls over, replacing my leaky plastic ones. The bottom of the aluminum bowll has an imprint on the bowl casting that reads 327389 D1. i suspect the one i need is 327389 D2.
the carbs have a plate screwed to the bottom with 3931176 140 171H
Is the difference in the structure of the float bowl itself or can i just change out jets or idle screws. Theses carbs have 25 stenciled on the side of the float bowl just above the float chamber plug. thanks for your help. Im hoping these will still work. thanks in advance.
