I have a 1992 150 HP Force motor. What should the correct compression be?
G grosnkrntz Recruit Thread starter Joined Jun 27, 2004 Messages 2 Jun 28, 2004 #1 I have a 1992 150 HP Force motor. What should the correct compression be?
eurolarva Rear Admiral Joined Jun 24, 2003 Messages 4,182 Jun 28, 2004 #2 Re: correct compression The numbers will vary depending on what type of guages you use, how warm engine is and so on. Good numbers would be around 135 to 150. Typical numbers will be over 100 and each cylinder should be within 5 points of each other.
