coring the transom
1man2beat
I would like to see what shape my transom is in. What do I use to core and where do I do this?
I am sure this is a dumb question, but I am just learning. "the hard way":(
81 Checkmate
re: coring the transom
What kinda boat you got? Go to the Resto forum and look at the sticky's at the top
All kind's of info!
Good Luck!
mwe-maxxowner
Master Chief Petty Officer
Just use a regular old drill bit. Drill in the center, toward the bottom. Near the drain plug. And take a couple moving up. Put a piece of tape around the drill bit to indicate about a 1" depth, or use a bit that only sticks about 1" out of the drill. I would use about a quarter inch bit. Look for dry blonde colored shavings. Reddish colored damp shavings are on their way to rotting. Rotted shavings are obvious.
1man2beat
ok thanks. I would drill from the outside right? What about the holes in the boat? Just patch over them?
Decker83
You should drill from the inside of the boat.. You can use 5200 to seal the holes..
mwe-maxxowner
Sorry, yeah I should have specified that. Definitely drill from the inside.
