starcentral
- Sep 27, 2018
- 39
I did most of my winterization in October which was non-ethanol gas with fuel stabilizer, changing oil + filter, and fogging engine until stalling. One thing I did not remember to do was drain the cooling water from the engine. The boat has been stored inside a large non-heated garage, and low temperatures were mostly 0 C degrees but there were some minus days in there. Worried, yesterday I went back to cottage to inspect the hoses and cooling water situation.
First thing I did was I pulled the blue exhaust manifold and block drain tubes and was happy to see water coming out. Then I opened up the 3 other tubes around the water cooling pump to take a look.
That's when I saw a bit of ice already start forming. I poured some hot water down to melt the ice quickly, let that water drain, then once satisfied most of the water was clear, filled it up with the anti-freeze and hopefully now have truly finished my winterization process.
