Cooling system on '74 Evinrude 15hp
Super Chopper
Took apart the water pump on this 15hp Evinrude. Water pump/impeller looks okay. While idle, it spits out water from the pee-hole. It's not a steady flow. Is that normal?
tashasdaddy
Re: Cooling system on '74 Evinrude 15hp
replace it if you don't know when it was last changed. they go out unexpectedly. looks normal running.
