Cobalt32
Thread starter- Joined
- Aug 6, 2017
- 28
454 mercruiser raw water intake. After replacing raw water pump all hoses, t-stat and housing, engine circulating pump. Engine has been running great at 160 degrees. I got stuck on sand bar today for less than 1 minute but definitely sucked up some sand. Less than 2 minutes into marina and onto wash rack. While flushing engine(inline flush fitting) i noticed engine sounding slightly different and exhaust water much hotter than normal. Checked temp gauge and found it on 100 and then jump to about 150 then back to 100. Shut engine down and it cavitated back on for a few seconds then shut down. I let sit for 10 minutes started right up temp jumped up steady but then dropped again. Thinking sand caught up somwhere, impeller trashed, t- stat clogged. Can a little bit of sand cause this much chaos?
