I have a question that you may have an answer to I just bought my boat with a 2000 Johnson 225 on it. It runs great but has a check engine light on all the time but that has been on since I owned the boat and it has never been a problem. <y question is this: I have a very solid stream from the cooling system leaving the engine but it appears that there should be 2 streams as there are 2 ports that would appear to be there to discharge water. Does your 225 normally have 1 or 2 streams discharging.
Thanks,
PaulCM
Thanks,
PaulCM
