Chuck4741444
- Jun 6, 2020
- 146
This a total rebuild on 96 Johnson j150exedb.
I finally got the motor running 800 rpm and water pump building up good pressure, but with the hose Muffs. this was my second water do to my mistake.
Wednesday, I had finally got the boat ready to take to the lake to set the timing at wot.
Thursday morning, I put the muffs on to double check it before I drove an hour to the lake.
I didn't notice the muffs had slipped off and had no water.
fixed the muffs and restarted a after it had cooled down a few minutes. the pump was not pushing a hard full stream for the pee hole. ( I have noticed in between water pumps the starboard side ran hotter than the pot side, by touching the heads.)
so I thought it was the impeller gone bad, pulled the LU back off, the pump looked ok buy i changed it to be sure. it didn't pump no better than the old one (a week old) used a water hose to flush the motor from each thermostat hole, pee hole and up through the water pump tube.
I put the lower unit in a tub of water to test the pump, first i used a half in ratchet, it pumped a little, so I used a drill to pump it, while it was turning, I put my finger over the pipe and its barley sprayed, building up no pressure.
put it together, tested it and still no water at all. i put back together< ran the motor, not water. pulled the boat out of my shop and called it a day.
when changing the pump i notice it took a lot of pressure to push the housing down. but it was sitting in the pump housing properly. i pulled back of to double check.
could the gasket between the motor and mid-section gone bad from overheating? it did not get so hot that it killed the Motor, but it was too hot to touch. why does the new pump have very little pressure when I tested it?
I'm dealing with short turn memory problems that only get worse over time and this creates a lot of mistakes. but I'm committed to finishing this motor.
the only good news is that can pull and install the lower unit fast. lol
I have a Selco and Johnson service manuals. and double check the parts needed using Crowley marine parts list to insure nothing is being overlooked.
