cooling alarm
spagi74
I had my 85 hp 88 force on water and cooling alarm would go on and off. Mechanic checked it and he couldn't find any problems. Same think happened today. When I run engine on higher rpms alarm would sound. Turned off engine waited and started it back on. Alarm sound again but I run engine only on low rpm and alarm turned of. Same thing repeated few times. What's wrong with that engine? Anybody knows?
fucawi
Banned
Re: cooling alarm
take the sensor out of the head and rig it up to your ohm meter or small bulb and battery ....then stick it in an electric kettle with a thermometer and turn on kettle ....check the temp it switches on....engine runs about 165 F so it should be well off at that temp ... if its ok check water pump etc.
