Re: Converting i/o to twin power towers!
Building a bracket is not overly hard but does require design and fabrication skills beyond the average backyard builder. Remember, your engines are depending on your bracket to hold together when it gets rough. I am pretty good with fiberglass and aluminum. I could build my own, but chose to buy one instead. Its just not worth taking the chance to me. There are several to chose from. D & D marine, armstrong, stainless marine, hermco, and there are several others. D & D is about the lowest cost at $700 for a single bracket with no platform to $1800 for a twin bracket with 8' swiw platform. Hermco is a fiberglass bracket and will not be subject to the corrsion problems that the aluminum brackets have. The aluminum brackets need to have a good quality paint job and it needs to be inspected on a regular basis for paint failures, cracks, etc. Actually the fiberglass brackets need to be inspected also. There are a couple of guys on ClassicSeacraft and ClassicMako that have built theirs using fiberglass. One other thing to look into is the length of your engines. Are they 25"? That is the most common setup for brackets, although a custom bracket with 30" engines would be better, as it would give a little more flotation and get the powerheads higher out of the water. I was running 25" engines and when in rough seas or even backing in moderate seas, it was not uncommon to see powerheads at least partially submerged. Just make sure all your cowling seals are good, lol.
