I have a Johnson 40 outboard and have a messed up fuel pump. My friend who is a mechanic in CA said that I should convert it to a premix set up. How can I find out what pump to get?
That's a BRP/Evinrude part number and the newest, so you don't wind up with old stock that's been in a bin for 20 years. Any BRP authorized dealer can get it for you, including on line BRP dealers such as marineengine.com, sea-way.com, ishopmarine.com and maxrules.com.
Go to the following link and select "looking to have my current engine serviced", then use your area code for a list of dealers: http://www.evinrude.com/en-US/Find-a-Dealer
Not really, the model had an alternative conventional fuel pump, part number 0438557, which is still available, but the 5005462 is less likely to be 10 years old when you buy it.
OK, I picked up the pump today ($109.43 after tax), and will start it tomorrow.
Does anyone know where I can find out which hose bib is for what? I know that the black one on the back is for the fuel in, but don't know what the other ones are for.
You have a fuel line in from the tank, a fuel line out to the carburetor, and a pulse line from the engine to drive the pump. The same lines can be used for the conventional lift pump. You will need to rig some kind of mounting bracket.
