Converting '68 350 to Electric start
Dynarace
My 1968 35HP #2154699 is running beautifully after I've rebuilt lower unit, carb, and fuel pump. But wanted to spend the winter tinkering an e-start conversion so that my 81 y/o dad can use it - it's too hefty a manual pull for him. I have found most of the parts I would need (flywheel, starter motor, relay, internal harness, starter wires), but am I crazy? Couple of big issues:
  • Installing starter motor - do I really have to remove the entire powerhead to get this to slide in from the bottom? I'm not sure after 45 years it's going to separate easily...
  • Any idea where I can get an external 6-pin harness for the key switch? I don't want to buy a whole other MerControl unit and nothing is showing on eBay...
  • Where does the solenoid mount? Can't find a picture of that...
  • Where do I find a proper flywheel puller for the old FW?
Any hints or suggestions welcome!
Dynarace
Re: Converting '68 350 to Electric start
Anyone got any thoughts on ANY of these issues?
Chinewalker
I'm not sure if you have to remove the powerhead on that one or not. I haven't had to remove the starter on my '67 and my '69 is manual start. I know I had to pull the powerhead on a '64 I had in the shop awhile back, but that's a somewhat different design.
Keep an eye on eBay for wiring harness. They do turn up from time to time.
Solenoid mounts on the starter motor itself - if the starter is OEM style, it'll have the holes tapped into the side of the housing.
You can use any 2-point or 4-point harmonic balancer type puller. Use Grade 8 bolts, 1/4-28 thread.
Nice motors - I really like mine!
Dynarace
Great, excellent information. Thank you for your very useful reply!
